nearpar
This is a 360 Dodge Magnum motor, block was in great condition when I received it had it hot tanked, new brass freeze plugs, all threads cleaned and tapped, Cylinders were honed, new rings, new bearings, new oil pump, oil pan. Heads were magnafluxed to check for cracks, new valve job and. heads shaved .010. Brand New Hughes Roller cam (SER1418ALN-10) .500/.506 lift 106* centerline .214 .218 duration. Brand new Air Gap ( Speed Master ) Aluminium intake manifold. Edelbrock 1905 Electric choke Carburetor, Professional products Harmonic balancer,
Mopar Magnum Aluminium valve covers, new fuel pump, Mopar Electronic Distributor.
I was going to install this into my Dart, but decided to go with a different project altogether. This motor has never been fired. $2800.00 Local pickup only in SE Michigan.
