Nick's Garage/UTG 318 Episode
Small Block Mopar Engine
Thread Status:
  1. RAMM
    RAMM Well-Known Member
    1,757
    1601
    Nov 22, 2010
    Ontario, Canada
    Local Time:
    3:08 PM
    I'm surprised nobody has made any comments about this lastest collaboration video.
    GOOD/FAST/CHEAP pick any two=UTG is FAST & CHEAP so we are left with an engine that is no GOOD. J.Rob
    • Agree Agree x 4
    • Like Like x 3
    • thesiren74
      thesiren74 Well-Known Member
      1,232
      808
      Feb 23, 2014
      kenosha,wi
      Local Time:
      2:08 PM
      Did you watch Tony live last night? He explained exactly what happened with the oil pressure loss and it totally makes sense. I had the same issue with my old 360 and a smaller base circle camshaft you need longer push rods because it'll create an oil leak from the lifter cup when the engine warms up.
      • Thanks! Thanks! x 1
      • RAMM
        1,757
        1601
        Nov 22, 2010
        Ontario, Canada
        Local Time:
        3:08 PM
        No it won't. That engine is eating itself. J.Rob
        • Agree Agree x 3
        • toolmanmike
          toolmanmike FABO MODERATOR Staff Member FABO Gold Member
          49,452
          34238
          Jan 18, 2006
          Iowa
          Local Time:
          2:08 PM
          Nick pulled a main cap and the bearings were clean. There sure was a lot of junk in the filter. The block wasn't cleaned much I would imagine.
          • Agree Agree x 1
          • skrews
            skrews Well-Known Member
            1,530
            1039
            Jul 20, 2012
            Washington state
            Local Time:
            12:08 PM
            Motors can be GOOD/FAST/CHEAP. You just have to have a clue of what you're doing. UTG not so much.
            • Agree Agree x 6
            • skrews
              1,530
              1039
              Jul 20, 2012
              Washington state
              Local Time:
              12:08 PM
              The amount of trash in the filter and the ridiculous miss on the lifter preload. :wtf:
              • Agree Agree x 4
              • toolmanmike
                49,452
                34238
                Jan 18, 2006
                Iowa
                Local Time:
                2:08 PM
                The rockers sure were noisy towards the end. Nick found leaking core plugs and a rocker shaft turned around backwards as well as all the dirt in the filter after running a short time.
                • Agree Agree x 1
                • RAMM
                  1,757
                  1601
                  Nov 22, 2010
                  Ontario, Canada
                  Local Time:
                  3:08 PM
                  Nick pulled one cap- ya gotta pull them until you find the problem.
                  I've been stung doing this myself. It only takes one wrong main to show what this one did. J.Rob
                  • Agree Agree x 2
                  • skrews
                    1,530
                    1039
                    Jul 20, 2012
                    Washington state
                    Local Time:
                    12:08 PM
                    Dude should stick to drinkin' beer, smoking cigarettes, and cookin' meth.
                    • Agree Agree x 5
                    • RAMM
                      1,757
                      1601
                      Nov 22, 2010
                      Ontario, Canada
                      Local Time:
                      3:08 PM
                      After the oil filter inspection, I wouldnt have even bothered pulling the pan, the day would be over. I sure as heck wouldnt be testing with all of the things I saw and heard wrong In that video. In fact I would have been investigating further just from how hard it cranked over. UTG told me they are always hard with new cast rings---lol. J.Rob
                      • Agree Agree x 3
                      • toolmanmike
                        49,452
                        34238
                        Jan 18, 2006
                        Iowa
                        Local Time:
                        2:08 PM
                        :rofl: +.030 rings in a standard bore? Sure they are tight. :lol:
                      • Dartsun
                        Dartsun Member
                        1,269
                        882
                        Feb 12, 2012
                        Springfield Oregon
                        Local Time:
                        12:08 PM
                        Hahaha Uncle Tony water is in coffee. My grandpa used to always say that.
                        • Like Like x 2
                        • 66jim
                          66jim Well-Known Member
                          474
                          446
                          Dec 11, 2007
                          NE PA ie pennsyltucky
                          Local Time:
                          3:08 PM
                          I can't understand the concept of time deadline TV internet dirt ball engine build, if you do some type of low buck build at least start with a core engine of known history. Not something that's been underwater. UTG now has egg on his face.
                          • Like Like x 2
                          • Agree Agree x 1
                          • Plymouth 65
                            Plymouth 65 Floorable Deplorable
                            1,052
                            952
                            Jun 27, 2016
                            Mich
                            Local Time:
                            3:08 PM
                            Perfect example of what not to do when rebuilding an engine. I agree, you can reuse components that are still within specification. But block cleaning is a must! I'm surprised that motor didn't spin a bearing after cutting open that oil filter! 65'
                            • Agree Agree x 3
                            • RAMM
                              1,757
                              1601
                              Nov 22, 2010
                              Ontario, Canada
                              Local Time:
                              3:08 PM
                              It is in the process of spinning a bearing, trust me. 2 pulls ain't gonna do it, by pull 13 is usually when you are safe. J.Rob
                            • QuickDart360
                              QuickDart360 Well-Known Member
                              1,150
                              406
                              Apr 5, 2014
                              San Antonio
                              Local Time:
                              2:08 PM
                              He had a hydraulic cam go flat and pretty much blamed the cam and lifters. However, he used whatever oil he got at the store. So he is not really informed/aware of specific oils to use with flat tappets.
                            • rumblefish360
                              rumblefish360 So close, yet so far away FABO Gold Member
                              38,048
                              9730
                              Jun 21, 2005
                              New York, on a Island
                              Local Time:
                              3:08 PM
                              He had Comp Cams lifters.
                              Here are mine after a cam break in on a fresh 340.
                              2873A868-F3BD-4C4F-98FA-511180D4089E.jpeg 5476F470-F85E-4D59-9AC7-1E73FC5A15E8.jpeg
                              • Like Like x 2
                              • thesiren74
                                1,232
                                808
                                Feb 23, 2014
                                kenosha,wi
                                Local Time:
                                2:08 PM
                                Be funny after the fix it runs just fine and you guys have egg on your face.
                                • Agree Agree x 1
                                • Cuda416
                                  Cuda416 Well-Known Member
                                  645
                                  268
                                  Jun 12, 2014
                                  South, TX
                                  Local Time:
                                  1:08 PM
                                  As I recall, the block that was brought for the build was not used. He donated one he had laying around, to the cause.
                                  • Like Like x 1
                                  • Agree Agree x 1
                                  • stixx
                                    stixx Well-Known Member
                                    785
                                    553
                                    May 30, 2006
                                    Southern Germany
                                    Local Time:
                                    8:08 PM
                                    For a guy who claims to be building engines for 44 years he is hilariously clueless and unprofessional.
                                    • Agree Agree x 2
                                    • xLURKxDOGx
                                      xLURKxDOGx "An angel fat, at satan's feast" FABO Gold Member
                                      3,752
                                      1223
                                      Dec 27, 2013
                                      PHX
                                      Local Time:
                                      12:08 PM
                                      Fanboy getting hot and bothered?
                                      Jake
                                      • Like Like x 1
                                      • SLOPAR72
                                        SLOPAR72 Well-Known Member
                                        2,126
                                        1521
                                        Jan 5, 2016
                                        Richmond, VA.
                                        Local Time:
                                        3:08 PM
                                        Nick can do far greater things with his content than fool with this guy. Not sure exactly why he got involved but if it sold ads and people are talking about it then Nick's garage will do fine. UTG has a cult obviously..... When I saw Nick turning it over on the dyno I went away. Pile......
                                        JW
                                        • Like Like x 1
                                        • Agree Agree x 1
                                        • xLURKxDOGx
                                          3,752
                                          1223
                                          Dec 27, 2013
                                          PHX
                                          Local Time:
                                          12:08 PM
                                          If anything he really wasted a real engine builders time by giving some half assed excuse why an engine that was thrown together with subpar reused parts turned out to be a garbage build. I’ll keep watching as this junk progresses. Living in the past tony. Let people who do it on a daily basis take care of it while you tell everyone about “nitro” and how you were the first to do “this and that” in the 80’s.
                                          Jake
                                          • Agree Agree x 1
                                          • A56
                                            A56 MoParAffliction FABO Gold Member
                                            1,017
                                            888
                                            Jun 24, 2014
                                            White Oak, N.C.
                                            Local Time:
                                            1:08 PM
                                            I'm wondering what the newbie is out financially or his thoughts about all of this? Haven't really heard from him about it. I also get all of the negative comments about the build, but labels about meth seems to be wrong. If you don't like what he does or how he does it, so be it ....turn the page. Just my opinion.
                                            • Like Like x 4
                                            • Agree Agree x 1
                                            • replicaracer43
                                              replicaracer43 Grumpy Old Man
                                              4,307
                                              3115
                                              Oct 10, 2008
                                              Local Time:
                                              2:08 PM
                                              You guys obviously haven't seem my response to his 5.7 hemi diagnosis! Can somebody link that thread here?
                                            Thread Status:
