No a/c vent door knobs
Boduke
Mass
Both my driver and pass fresh air vent doors are missing the locking knobs. Thwy doors and hinges are fine. Are they available or does anyone have a white trash fix? The doors under the dash that blow fresh air not the fly windows. Right now i have them taped shut
Thanks in advance.
Thanks in advance.
Good to ask questions but a wanted ad would work best.
Bolt on a small drawer pull knob from lowes or home depot where the old handle was. Fashion up a bracket to mount on the box itself with a fairly strong pill magnet. And adjust the bracket so magnet touches the steel on the door to hold the door shut tight.
I have never seen reproduced lever/handles. You will need to fashion something. We usually replace the vent with a good used one or drill the rivets out and replace the door with a good used one.
Thanks Mike - I figured that might be the best way. Will need to pull the box to drill out those rivets.
The vent assembly is usually attached to the underside of the dash with long with hooks on them.
I believe there are nuts inside the air box to loosen.
