Hi, I have a problem with no rear brakes on my 72 Swinger.
Technical
74 front spindle Actually replaced the whole K Member
76 Cordba 11-3/4" front disks and calipers
using a manual brake set up 2 bolt master cylinder from later model Mopar
New disk brake proportioning valve
81 dippy rear brakes
All new brake lines
All parts listed are NEW
Problem no rear brakes.
I have bench bled the MC
Bled the brakes starting with RR
tried resetting the proportioning valve
Good hard pedal
Every thing seemed OK till I noticed the the front disks worked fine but I had no rear brakes.
When I remove the rear brake line from the proportioning valve and apply the brake I get no fluid coming out of the proportioning valve.
Technical
All new brake lines
Good hard pedal
