The other thing you could do is "jig it up" that is get it down to as simple as possible and eliminate as much as possible Some other random thoughts.
1...What is battery voltage and what is battery voltage WHEN CRANKING at the ballast? hook a meter to the ballast with key "in run" (engine stopped) and make sure you have the "key" side which is the highest reading. This reading should be "same as' battery"
2....Clip meter to coil +. Voltage will / should be much lower, perhaps 6-9V. Now crank engine USING KEY while reading meter. Voltage should be "same as battery" whatever that is during cranking, and should be ABOVE 10.5V, the higher the better
3...you can hook a meter to the distributor pickup connector on low AC volts and either spin dist. or crank engine. Distributor should generate about 1V AC
4...Don't guess make ABSOLUTELY CERTAIN box is grounded. To test, turn key to run, make sure coil + terminal is NOT 12V but rather lower, 6-9V This shows coil is drawing current through box, which is correct.
5....Also "rig" a test gap using a solid core wire and gap or spark plug right out of the coil tower. Cranking should give a nice hot blue spark at least 3/8" and typically 1/2" long
6....Pull distributor connector apart, turn key to "run". With your test gap rigged, repeatedly tap the bare terminal of engine harness end of the dist. connector to ground. Each "tap" should give 1 single spark "snap" at the coil
Here is a copy of a post I made some time ago, that is meant to be a help in understanding the hookup and how and why
You need a coil, the ECU and the distributor
Lay it out on the bench. Follow the diagram. Find the two distributor pickup terminals on the ECU. Hook them to the distributor
Hook the ECU case to battery NEG
Coil does NOT need grounded
Distributor does NOT need grounded.
Hook coil + to the power lead terminal on the ECU. Get a clip lead hooked there and let dangle. This is your battery "hot" when you are ready
Hook something from coil "case" to a probe for testing spark.
Hook up your power clip lead. Twist the distributor shaft while holding the test probe near the coil tower. The thing should make sparks
If not, unhook distributor. Take first one, then the other pickup clip leads, and "tap tap" ground them at the battery connection. Coil should make 1 spark each time you do so.
If not, try another coil. If that does not fix it replace the ECU
IF you hook it all up and it WORKS, then there is something AFU in the car harness. SUSPECT a bad ECU connector OR a bad DISTRIBUTOR connector
This is all you need to test the basics of the ignition. You can easily test the ballast separate. A battery, the ECU, distributor and a coil, and of course some test leads
Below, the basic diagram for a 4 pin ECU
Below, the wire for testing spark. I use my 12V test light. No, LOL the spark won't blow up the bulb
Below, the ground connection. ALL you need is one wire from batt NEG to the ECU case
Below, the two distributor connections. In the car these are polarity sensitive, but for testing does not matter
Below, the coil NEG connection
Below, battery PLUS connection, one wire to this terminal of ECU and jumpered over to + side of coil
Below, all hooked up and ready to test (except for battery ground). Should produce sparks at least 3/8" and typically 1/2" long
Below, distributor "one wire" test. I have removed the other distributor wire for simplicity. Take the bare connector end or this clip lead (the yellow) and with everything hooked up, ground it repeatedly. Each grounding should result in a spark (In this photo you need to hook up the ECU ground wire, I left it off for the photo)
