No Spark! Help Please!
Zinger74
Active Member
I have power all the way to the top of the distributor but no spark. I changed the disributor, the cap, the plugs, ballast resistor. I dont know what else to do. Its a 74 duster.
ignition module?? maybe a bad ground. New distributor or different old one..... might be a perfect time to go HEI
make sure the ignition box body is grounded to the chassis. My did this one day and the car wouldn't start.
Was this a running car and then boom or ??? Give us some more details.
Frank
It was a bad ground to the ignition box. Another problem solved thanks to FABO!
