No Spark??
lebdog74
Active Member
Osterburg, PA
Ok, STILL trying to get my Duster to fire but still not getting any spark. I have power to the coil but no spark coming out of it. Same thing with a second coil that worked a few years ago when it was taken out of the car. I had the ignition control module tested at autozone it was good. Even tried another module, still nothing. Any suggestions??
Disconnect lead from coil neg. Jumper the neg to ground. remove jumper, if coil is good will have a strong spark.
Hey Lebdog, I'm having the exact same problem at the moment. Coil has power to it but cant seem to get any spark to the dizzy. I just replaced the coil to a brand new MSD master blaster coil 2 and still nothing! If you come up with any more ideas please let me know and I'll do the same!
@dustuoff- it turned out to be the ignition switch. replaced switch and tumblers starts fine now
