believe this is appropriate for both mopar and HEI.
on the approach the reluctor peak causes the voltage to swing low and the low dip gets bigger the closer the reluctor vane gets to the pickup centre
when aligned though, its at zero because the voltage has to change direction when the reluctor vane swaps from approaching to leaving the pick up
as it moves away the voltage swings high
at the correct + voltage trigger level a spark is created, and as you can see with a fast rpm you get a bigger voltage peak than with a low rpm small peak, for both cases the trigger point varies by only a tiny amount, a very slight retard built in, that is linked to RPM
swap the trigger coil wires round, (impossible with an offset mail/female mopar plug, you'd have to cut it off) and you start triggering off the dip in voltage.
and the start of that curve and the bits that hit the trigger point on the negative side are miles away from each other, a truly unacceptable variance in timing vs rpm caused by the trigger coil being connected into circuit backwards.
always trigger after the voltage swings+ and crosses the 0 value on the y axis (voltage) doesn't matter where that is on X axis (time) because time is linked to RPM and you SET your timing.
this is totally dependent on the shape of the swoop down, abrupt up (trigger on this), swoop back down signal created by the reluctor approaching and leaving the magnetic field centred in the middle of the pickup.
if it helps turn the image upside down to indicate backwards wiring of pickup
