A friend has a 69 Barracuda, has 340 with electronic ignition. the first crank it starts right up, after you drive it when you turn it off it will just crank till you let off key then it fires. Has anybody got a fix for the problem. Thanks Mike
Is this 2 or 4 terminal ballast resistor? If this is a 2 pin resistor, might be the start circuit, either ign switch, connector, or bulkhead connector
There is a separate contact in the ign switch which feeds power during start out through the bulkhead to the + side of the coil on the brown wire. This is known as "IGN2" or the "bypass" circuit
Only does it after warmed up though.
Wire wound resistors (Ballast resistors are wire wound resistors) can open after it warms up (due to current flowing through it) and after it cools it can make contact again (internally) and pass the voltage through to the coil.
