Cudaize
NORS CA-305 2863349 Air filter Unsure of manufacturer or actual part number
OD 12-13/16", ID 11-1/16", Height 2-3/4", these dimensions are the same as some NOS CA-305 filters I have
I picked these up without any packaging from a swap meet a couple years back
The rubber is a little darker red than Fram, the perforation holes are smaller and not puckered. The inner screen does look to be metal.
Not the filter if you are going for an OE restoration but an economical choice if it is close enough for you.
Used on several 2 and 4 barrel applications from about 1968 until early 80's including 70-71 340, 383, and 440
$50.00 including shipping in lower 48 states.
