justa170
Member
One (1) genuine Carter BBD 6537s 2-barrel carburetor in new old stock (NOS) condition for $269. This item has never been installed, used, modified, rebuilt, or remanufactured. It's still in the original plastic wrap from the factory.
The Carter BBD 6537s was original equipment on some 1974-1976 Dodge trucks with 318ci V8 engines. It features small holes in the throttle blades to improve idle quality in the 318 V8 (see B&W photo).
This carburetor will fit many applications, including some "slant six" (Chrysler OHV 225ci, 198ci, and 170ci inline-6 engine) setups. Note the choke linkage will need a minor modification to work with slant six engines. BBD's also fit some 273ci Chrysler V8s. I can try to help you figure out if it will fit your car or truck.
If you want a perfectly-matched set of these for a multiple-carb build, I can hook you up. If you're crazy enough to build a quadruple-carb intake, I can sell you four mechanically identical NOS carbs.
I'm located in Medford, Massachusetts. I should be able to ship your carburetor(s) within three business days of cleared payment.
NOS Carter BBD 6537s 285CFM Carburetor 273 318 V8 or 170 198 225 Slant Six | eBay
