383Duster
I discovered this summer my Duster would start in gear.........I bought a new neutral safety switch and installed it yesterday and still have the same issue. Followed wiring up to the firewall and discovered one of the three wires was taped up in the harness. The other two are plugged into a connector with a shallow V shape. From searching the forum it appears the wire I found taped up goes to the starter relay. One terminal on the relay has been grounded........see pictures. Am I on the right track here??
thanks in advance
thanks in advance
