[FOR SALE] NV3500 Dodge Dakota Transmission
Magnum87
Ohio
Rating - 0%
0   0   0
Have a NV3500 2 wheel drive transmission out of a Dodge Dakota. Also have a 5.9 Flywheel and clutch and pressure plate with arp bolts. New hydraulic clutch master cylinder and slave cylinder. Also includes a Hurst Shifter the handle was bent by the previous owner then welded. Have to use the adapter to use this shifter on this year tranny. This is the older style Hurst Shifter and this is a newer tranny. But it works with the adapter. U can change the handle to whatever u like. Not looking to separate at this time. Transmission has low miles. Will bolt to Mopar Small Blocks Located In Amherst Ohio 44001 $750
