Odd SBP 15 “ rallye wheels
ClassicCarGuy
69 (R6) Red ‘Cuda
Suburbs Phila Pa
I have two 15” small bolt pattern (4.0”) by 7 3/4” wide rims. They came with tires I purchased. The center hub opening is approx 2 3/8” diameter. The rims look fairly new and I haven’t been able to locate a mfg stamped number. I’m guessing they are a reproduction rallye wheel. Are these suitable for sbp a bodies? If not, could someone please tell me what car(s) might accommodate/utilize this combination rallye wheel. I’d like to move them out, but not certain they are a Mopar suitable rim.
Thanks for your help!
Wheel width is measured inside the beads.
Got a close up shot of the red sticker?
Double check your measurement for the bolt pattern. Measure from the center of 1 lug to the rear of the lug across.
I don't think those are 4" SBP
I had a set or two SBP 15 X 7''s custom made by Willamette Wheel in Portland, OR over 40 yrs ago. I'm sure others have done the same thing in other places in the US in the past 40+ years. Wheel Vintiques is a recent, popular one.
