[SOLD] OEM car style 360 oil pan #438, HV oil pump and P/U plus attaching bolts
physixx
Edison, NJ
I have for sale an OEM car style oil pan that was from a 1971 360 block. This pan will NOT work with a 273, 318 or 340 engines. It has #438 stamped on the bottom of the sump and will fit any of the 360 LA engines. Not sure about the Magnums though. Fairly dent free but the inside can use some bead blasting to get the surface rust out. It’s got a primer coat of paint on it so can be painted the choice of color. In addition, a very little used Melling M72HV high volume oil pump and the oil pump pickup is included. Finally the oil pan attaching bolts go with it. The oil pump was disassembled and found to be in super clean condition so was put back together and is ready to go. I would like to get $46.00 for everything plus the shipping.
Ken
Edison, NJ
