Off idle stumble edelbrock and 340!!!!!!!!!!!
kt340sport
Miramichi N.B Canada
Still have a nasty stumble in my 73 dart sport 340 stock engine , with the excep of 600 edelbrock , its when leaving lights and stop signs , at high rpm doesn,t seem to do it stock intake spacer and carb , car seems to idle great, and takes it fuel good under quick acceleration , and has good flow of fuel at both nozzles , antbody have any suggestions , very annoying.
I had the same problem at the drag strip a couple of weeks ago. I got a calibration kit for the carb and went one jet bigger, problem went away.
accelerator pump drive linkage,the pump shot may not be big enough.whats your initial timing set at?
