[FOR SALE] Offenhauser Dual 1 Bbl Slant 6 Intake complete with 2 Matching New Carbs, Linkage etc.
slant six
Do More With Less
IRWIN
Hello, here is a nice Offenhauser Dual 1 Bbl Intake with (2) NOS never been used matching Carter BBS № 3278S carburetors.
  • The throttle linkage is sorted and installed works and moves freely, and is adjustable from curb idle to WOT.
  • A bracket for the transmission kickdown linkage is included. (I suspect there is still some fabrication to be done on your end if using an automatic, but the beginnings of retrofitting an existing 1 bbl slant 6 to this linkage should be straightforward with a bit of thought and fabrication skill.)
  • Fuel lines bent and sorted nicely.
  • Setup to use an existing 1 barrel throttle cable / A Body 1967-76 FJM Body with a 1 barrel, B/C/E Body / Truck with a one barrel / super six throttle cable.
  • If intending to install on a 1960-1966 A body I would recommend swapping to a throttle cable instead of a throttle twisty rod.
  • Intake has been used maybe for just a small amount of time. I bead-blasted it so it looks new and clean. The inside had no noticeable gasoline scum / black reversion goo in it.
  • Carbs are NOS with manual chokes - I would assume that one choke would be needed for quick starting.
  • Brackets and linkages/intake plugs have been recently detailed and painted black.
Asking $950 Plus Shipping from 15642, PA
This should be a fairly fuss-free dual one barrel - Add your air filter and housings and be good to go.
Interesting, I've always wanted something like that to mess around with. $750 is a bit of cash, but then again, where else will you find something like this? I'll keep this message and think on it. For now, I just want to get the engine running reliably. I've done some kickdown linkage fabrication many years ago, I'm sure I can make it work.
