Offenhauser tunnel ram
Cudaboy17
Active Member
Winnipeg
As no one locally can flow intakes, I'm curious to see if anyone has flow tested a offy tunnel ram for a small block. If so what are the flow numbers?
check out HRM on line they did big block and small block manifolds mopar muscle then engine
I did look at the hot rod small block intake shootout but it doesn't look like they did an offy. Do you have a specific link?
