Oil Cooler
Use a remote oil filter and plumb it to the cooler from there and then back to the engine.
Are you having trouble with high oil temperature?
I have a champion radiator right now with a trans cooler but I have a manual so I don't use the trans cooler can you run the oil through the trans cooler.
What's wrong with 200*? That's plenty cool.
Yeah. The formula for figuring out your boiling point is for every 1 pound the cooling system is under, it raises the boiling point 3 degrees. And that's with water. Coolant ha a higher boiling point. So that means with water and a 15 pound cap you raise the boiling point from 212 to 257. You gotta ways to go.
