So today I was going to put on my oil filter and don't know which one I should use. I would think for simplicity sake the stock oil filter plate would be less prone to leak, because I've read on here some people have leaks even with the correct gasket set.
If I use the stock oil filter plate is it recommended that I drill four more holes into it? it currently has 4. What is the gasket kit for this? Isn't it a simple O-ring? Would this fit with a set of LT headers? If not I guess I'll have to use the 90 degree adapter.
Now my question about the adapter is about the bolt that comes with it has two offset holes that go through it. I've read from somebody on here that I would need to use a different bolt for a high volume oil pump, Is this correct?? I don't know how reliable that source was, and they weren't too sure either.
Now about the adapter gaskets, would this be the correct kit? At least this isn't really a big issue. Thanks.
http://moparperformance.carshopinc.com/product_info.php/products_id/37213/P5249320
