I have been told to drill 4 more holes in the oil filter plate for less restriction of oil flow , , is this something that most are doing on a rebuild ?
Enlarge them to what size? I have a drill press but I don't have any milling equipmentThat was my thought, enlarge existing holes, and I'm glad somebody more knowledgeable chimed in.
Just use your porting tools. It doesn’t have to be accurate.Good info guys, one of next steps in my build is installing the filter plate.
No I don't. Mine leaked less when I tightened the oil filter a bit more...but it still leaked, and the oil filter was over tightened compared to what I normally do.Small round file for the holes. Do you think the center adapter fitting does all the work sealing the OD of the plate against the block? Think about what happens when you screw the filter down on it.
