Dartvader440gt
Does anyone use these? Are they better for header clearance? What's a good one to use?
I'm using the TTI shorty's. I'm glad to know that I will need it. Thanks.They aren't needed on Doug's or the TTI longtubes. On the TTI shorty's you need them. I don't use one as I prefer to just have the filter attached to the block itself. Less chance of a leak.
Make use of lines like Oldmanmopar above my reply.Great thanks.
Too late. It's already on order LOL. Besides, it will give the old school drag car look I want.I run TTI shorties on my 360.. no adapter. Works fine for me.
I had the adapter too, still have it just in case I change my mind. I had been using the shorty WIX 51068 filter but replaced it with the fill size WIX 51515 and a heat shield.Too late. It's already on order LOL. Besides, it will give the old school drag car look I want.
Nope... works as intended so far. Slip it on and forget about it until time to change filter.Thanks. You've had no problems with the heat shield?
