Oil filters
408stroker
408stroker
Uxbridge Massachusettes
I am looking for a little help I am having an issue with my 360/408 of keeping the oil filter from leaking at high rpm I was in the waterbox and it started leaking again. it will also push oil at the top end of the track and burn off the headers. any one had this issue
What is you oil pressue at? You are certain it's the filter? What filter do you run now and how does it leak?
