I just read (after filling it with 80W-90 and driving 50 miles) that non-synchro 3-speeds take automatic transmission fluid! Anyone know if that's true? If it is, I have to get that gear oil out of there ASAP! This is in a '65 Dart with a Slant.
I may indeed go with the lightest weight Mobil 1 synthetic.You old 3spd takes just regular gear oil , if you want to go hog wild use synthetic
For the top cover and tailpiece gaskets, just get some gasket paper and cut out a new one! Easy-peasy....RTV just ain't gonna hold for long.My other problem is that it's forcing oil from somewhere when the car's moving. The vent makes sense, but it seems dry up there. There's a chance it could be blowing it back so it doesn't land on the top of the trans, but leaks down the side. It's definitely coming from up high. My local trans guy put front and rear seals in it and used RTV for the top cover. It could be coming from the tailshaft to main body gasket. Who knows, but finding parts for this thing is a bummer! Good luck with yours!
