racing340 Member Joined Apr 14, 2010 Messages 22 Reaction score 1 Location Leicester NC Oct 17, 2011 #1 i have an oil leak coming from the rear main seal area it seams to only leak when im running the car. Is it do to the crankcase pressure i was told the breathers on the vavle covers would be enough? Any thoughts thanks!
1 1wild&crazyguy Banned Joined Jul 11, 2009 Messages 7,751 Reaction score 241 Location Surrounded by mopar Oct 17, 2011 #2 rear main seal leak should steady drip and or lightly piss out the back. die test it and use a black light to find the source. google 'die testing oil leak' The rear main has direct oil psi coming from the rear main bearing, if the seal was dry when 1st fired, no silicone on ends, or ?..it will leak
