oil level
The level of oil gets to close to the spinning crank shaft it will whip air into the oil. You don't want air in the oil.
Too much oil will also lower HP output.
Chuck
too much oil can also blow seals front seal rear main those type of seals can blow out if too much oil is in the engine.
Chuck
Yep, don't want to do that, if its a newer car, all sorts of issues can come about with different emissions controls and such.
Vacuum systems can get plugged up on newer cars.
GREAT REPLIES.
To much oil will get whipped by the crank which is resistance and cause a HP loss. The resulting foamed oil is something the engine doesn't like and if the level became low due to a high RPM run, the engine will be unhappy sucking up foam and show a pressure loss.
