604
OK I am an idiot,
It has been since High School since I put a mopar engine together, and I am having problems with the oil pan gasket. I think I know the problem, but not sure.
I followed the old SB Mopar rebuild book, and I think that is the problem. I did like they said and used RTV on both sides of the end gaskets and the cork ones. Well I go to tighten up the bolts and the gasket squeezes out. One big mess!! Am I correct to assume that you only use RTV in the corners, and the rubber ends?? Thanks for any advice!!!!!
