72swingerwoman
Active Member
- Joined
- Jul 9, 2007
- Messages
- 38
- Reaction score
- 0
i need to replace my oil pan gasket which should be a simple task, but i have a protective metal shroud that is right under the pan that is welded onto the frame. there is a whole cut out for the shape of the pan, but i cant get to the bolts, that are not tight either, i tried to get them tight but no matter where i try to get to them i just cant get any type of tool on them god enough to get them tight.
i really didnt want to pull the engine out until i was ready for body work and paint.. is there a way to maybe just jack the motor up with out having to take it all the way out? and how does one do that. never done that .. taken motors out before, i just dont feel like doing that if i dont have to! can i just undo motor mounts and jack, or do i have to worry of tranny also?
previous owners i guess didnt believe in tightening anything down, that they worked on!
