OIL PAN SUMP PICK UP LOCATION QUESTION
CFD244
"THE NEW OLDSMOBILES ARE IN EARLY THIS YEAR"
Northern Ontario, Canada
Hi Folks
I would like to know how far from the pan that the pick up gets installed. I know that it is very near to the bottom of the pan, but I'd like a number. Oem pick up, and OEM pan on a 340 Demon.
Thanks FABO
OEM stuff. touches the pan. Imprint in the muck on stock application.
I left mine hanging a bit "low" so when pan went on with gaskets, I had to "force/push" pan on. That gave my pickup that last little twist of tightening it needed.
