OIL Pan ?
Whichever one doesn't hang below the k member.
X2^^^^ keep it above the k-frame!
Yup dont want to hit a low sitting oil pan on every little bump you see...or dont see.
I'm using a Milodon 31581 road race pan on my raised deck in a '67 Dart. It isn't quite flush with the k-member, but it only peeks out maybe 3/8".
Thanks for all the help , I'll check out the road race pan
I forgot to mention, I'm using Pro Parts headers. And they clear with ease. I had to clearance the K-member quite a bit for the external oil set up, but I'm sure you'll be fine with the non external pan.
