Budgetmoparman
Earlier this winter I dynoed my 340 and the oil pressure on the dyno was hitting 140psi. We made 10 pulls and it kept hitting the 140 mark. At that time it had a melling HV pump and 15/40 oil with zddp additive for break-in. When I got home I swapped the hv pump for a melling standard volume pump and dumped in 10/30 with zddp additive. I finally got the motor in the car and fired it up today. Oil pressure at idle is 80psi. I haven't ran it up in rpms yet because I don't have the radiator hooked up so I don't want to run it too long. Any ideas why the oil pressure would be so damn high? Motor is bored .030, comp XE268H cam, adjustable rockers from a 273, 340 X heads. I didn't do any oiling mods to the motor. It ran great on the dyno except the oil pressure. Any help is greatly appreciated.
