Oil pressure / rebuild
Patrykdart70
F'n New Guy
Fullerton, CA
Hey guys,
I have been having issues with the cars oil pressure.. I get about 2lbs psi and have checked the spring and piston in the relief valve.. I have been entertaining the idea of puling the motor to get the pump off and replacing that.. The car had been sitting and the valves were caked in old oil. I was thinking something could be plugged.. if the pump were operational would it brake the junk free? also if I pull the engine where is a good place in SOCAL to do a complete rebuild?
thanks for the advice in advance, I'm glad I found this board!!
