Oil pressure sensor location on 360 magnum
Abodysrule
California
Where to folks put their oil pressure sensor on a 360 magnum? I plan to use a 90 degree oil filter adapter, it has a plug, anyone put their sensor there?
Brian
Where it’s supposed to go works good. Top of the block at the back.
you could take a mechanical feed or temp gauge at the spot you’re asking about. If you do make sure you our a plug in the oem location
Pic of standard locale?
See attached photo
