Oil pressure switch
Slant 6 Engines
  1. sireland67
    sireland67 FABO Gold Member FABO Gold Member
    9,287
    3476
    Oct 27, 2010
    WV
    Local Time:
    3:58 AM
    On a 225 slant is there any other source where a mechanical oil pressure gauge can be hooked up?
    I was going to tee at the oil pressure switch and add a pressure gauge, but the stock switch is super tight.
    I put a socket on it with a 1/2" rachet, at it does not want to budge. I am afraid to break the stock sending unit off if I put any more pressure on it.
  2. 67Dart273
    67Dart273 FABO Gold Member FABO Gold Member
    44,989
    12581
    Oct 14, 2010
    Idaho
    Local Time:
    12:58 AM
    I'm not a slant expert but offhand I'd say "if there was one" then "everybody" would be doing it. Instead of arguing "down there" with all the tees and elbows and fittings in one hell of a tight spot, maybe? it might be easier to come off the engine "as you can" with a good quality hose assembly (no3 AN or something) and remote mount "the mess" that is the sender/ tees etc over on the firewall somewhere
  3. RammerJammer75
    RammerJammer75 Well-Known Member
    463
    594
    Aug 28, 2020
    Kingsport, TN
    Local Time:
    3:58 AM
    Can you heat it some to see if that will help?
  4. sireland67
    9,287
    3476
    Oct 27, 2010
    WV
    Local Time:
    3:58 AM
    That is about where I am at, need to clean all the old oil and grease from around it.
  5. Badvert65
    Badvert65 Long Time Mopar Nut
    327
    106
    Sep 21, 2014
    Brightwood, VA
    Local Time:
    3:58 AM
    If you don't connect it at the pump with a Tee, then the only other option is to drill and tap into the main oil galley on the lower right side of the block, just above the oil pan rail.
    jus sayin....
  6. slantsixdan
    slantsixdan =..=
    6,737
    1908
    Jan 7, 2007
    Vancouver BC
    Local Time:
    12:58 AM
    There are usually two places you can pick up oil pressure without major (or any) surgery. One is the obvious location at the rear of the oil pump where the pressure sender is usually screwed in. The other is at the rear of the main oil galley on the distributor side of the block—there's usually a pipe plug, same 3/8" NPT thread as the sender port in the oil pump. The factory put the pressure sender there in some '63-'64 motors (with a pipe plug in the oil pump), but on very hard braking sometimes this location would momentarily run low on oil, making the oil pressure warning light flicker and frightening Mr. and Mrs. Carbuyer, so they moved the sender back to the pump and issued a TSB for dealers to do the same for whoever came in with that complaint on one of those cars.
    • Like Like x 1
    • Thanks! Thanks! x 1
    • sireland67
      9,287
      3476
      Oct 27, 2010
      WV
      Local Time:
      3:58 AM
      Thanks Dan, I will look for the extra pipe plug.
    • Naplm00
      Naplm00 Well-Known Member
      233
      48
      May 20, 2019
      Bay
      Local Time:
      12:58 AM
      Good to know! Mine is on the back of the engine in that spot...64
    • theFightingFew
      theFightingFew Always Learning/1975 Valiant Custom/1974 Valiant FABO Gold Member
      112
      146
      Apr 9, 2020
      Philadelphia, PA
      Local Time:
      3:58 AM
      Has anyone ever used a "sandwich plate" that threads into the oil pump between the pump and filter and has multiple threaded holes? I'm having a similar no budge issue on my sending switch... I already made up my T and all but thought the sandwich plate could be a cleaner option.
    • sireland67
      9,287
      3476
      Oct 27, 2010
      WV
      Local Time:
      3:58 AM
      I think the plate would be a bigger pain than taking the sending unit out.
      I cleaned most of the grease from around my sending unit, I will clean some more tonight.
      And heat around the sender and see if it will come out.
      I did modify a small block plate spacer for the thermostat to hook a mechanical temperature gauge, not quite finished with it yet.
    • diymirage
      diymirage HP@idle > hondaHP@redline
      20,330
      14707
      Oct 12, 2012
      michigan
      Local Time:
      3:58 AM
      never used one on a classic but ive had them on imports with good success
      • Like Like x 1
      • sireland67
        9,287
        3476
        Oct 27, 2010
        WV
        Local Time:
        3:58 AM
        I got the sending unit out last night, heated around it for about 30 seconds with some MAP gas, gave it one hard push with a 1/2 ratchet and it spun loose.
        • Like Like x 1
        • RammerJammer75
          463
          594
          Aug 28, 2020
          Kingsport, TN
          Local Time:
          3:58 AM
          Good to hear!
        • sireland67
          9,287
          3476
          Oct 27, 2010
          WV
          Local Time:
          3:58 AM
          I am glad its out also, when I was pushing on the rachet all I could think of was don't break off, I had visions of angle drills and easy-outs were going thru my head.
          The heat made a difference, looking at the end of the sensor it looks like it may have had some sludge build up on the end of it.
        • diymirage
          20,330
          14707
          Oct 12, 2012
          michigan
          Local Time:
          3:58 AM
          no kidding
          i had a brand X family hauler a while ago that has oil sensor issues
          so i bought a new sensor and while installing it, it broke of
          now i had basically a 3/16 hole for oil to escape
          not a fun project
