oil pressure?
harrytoes
Encinitas, Ca
My stock 318 in my 68 fastback shows that I am getting really low oil pressure from the in dash gauge. I got an external gauge to use but how do I get at the sensor next to the distributor. There is no room to get in there what do I need to remove to get at the thing?
There are oil pressure sensor sockets but I have had luck with either a 15/16 or a 1" deep socket on some of them. You may be able to see it better with the cap off, but you might have to pull the dist.
