Sedanman
67-9 Valiant specialist
Is it better to have a high pressure oil pump for roller lifter engines or HV? I have a new HV in stock
Just a lower mph.lolBeen using HV pumps for decades. Never an issue.
There is not explicitly an HP pump for the SBM.... you can put the higher pressure relief spring in either the STD or HV pumps and each will become 'HP'. The roller and non-roller pumps all interchangae, but I cannot tell you if the roller engine oil pumps all came with the higher pressure spring; you have it anyway if you have a Melling pump.A friend swapped a Magnum in his 68 valiant and said he used a HP pump instead of a HV. I assume he did that because of the roller set up?
M72 on the box
I'd see if it was marked on the casting. Yes, the M72 is the Melling standard pump housing. M72HV is the Melling HV housing, which is just a little bit taller but the same shape. These are the only 2 Melling PN's for SBM pumps.M72 on the box
