Nick Morganelli
NM1951
help on replacing front and rear oil seals on 360 engine without pulling engine out
thank you for your information,Help? Drop the pan.
You can't change the rear main seal, or rear pan seal w/o removing the pan.
Lift the motor some up off the mounts, about 2 inches maybe.
Just remember to drain the oil 1st n pull the dipstick out , wipe it...and put it on the windshield under the wiper so you do not forget to fill it before fire up.
The mounts may or may not be in your way as well.thank you for your information,
