Thought I had the cover too in my photos, have take another pic tonite. I drilled and taped the cover for the pickup tube attaching from the 3.0 engine (1” diameter pipe) and the bell bottom end. I’ll remove the filter so to ease up restrictions from the pump thru the system then turn down the pressure to push the oil which frees up HP. You don’t need a filter for 1/4 mile at a time.
