This stuff has the most zinc additive I have seen in engine oil. 2300 ppm! All sounds good for flat tappet cam shafts. But, the thick viscosity concerns me. Will this put uneccesary strain on the distributor drive shaft since this oil is quite thick. Does anyone use such high viscosity oil on their small block? Or shall not use it at all.
Regards
Billy D.
If you really want to use it, then I would cut with something else for two reasons.
2300 ppm is well into the range of bad effects from too concentrated zddp. Somewhere's north of 1400 or 1600 one can expect it to have negative effects. I post up some reference citations later tonight - and then you can decide.*
The other reason is that it is way too viscous unless your running a situation where the oil gets really hot - like a Silver State or road racing. If its too thick, there will be plenty of pressure at the pump, but too much will get dumped out the relief valve. In other words, the volumetric flow through the engine and up to the top may be worse.
Here's a viscosity calculator for mixing any two oils.
Mixing viscosities | Widman International
The viscosity of pretty much any oil can be found on the manufacture's website. Some are easier to find than others, but they all have it. It will be given at 40 C and 100 C. That's the standard. So to know how it will work out at colder and warmer temps, do both. Then punch it into the graphing calculator and you can see how it stacks up against a typical or specific 10W-30 or 10W-40; or any motor oil you want.
Graph your oils | Widman International
To focus on operating temps, enter a higher minimum temperature.
*edit: 800 ppm will protect very high pressures on the lobes. But of course a little higher will not hurt and could help because there's always factors of uncertainty. Overtime some of the zddp will be burned. The more there is the more will turn to ash. Thats not good. (ref
Widman's Oil for Corvairs pdf). SAE papers reported that over 2000 ppm, the ZDDP will attack the grain structure of the steel. That's mentioned in a few places including this
circa 2007 rebuttal to Zinc Myth. So I'll stick by my 1400-1600 as max desirable even in a racing engine with high spring pressures.
