I'd have to smell it to tell rich/lean as a lean out has a distinct smell. But you should be able to track this glitch down pretty easy. Black plugs, black smoke? Oil turning black quick and smelling like gas? First, 99% of carb problems are ignition related. And as you said you have switched carbs without affecting the problem, we can probably rule out the carb pretty quick. Have you swapped the distributor itself? Lets work one side then the other. Lets touch on the carb real quick. You've said a couple things that have me scratching my head. "The choke isnt even on" has it been removed from the carb? Is the wire not hooked up to the electric thermostat? If the choke has been removed from the carb, the "hacked carb" flag goes up, but you also say you have swapped carbs without changin the problem. If the choke is present, but the wire is not hooked to the thermostat, then the coke is probably on, whether you want it on or not. I am assuniong this is not the case, but let's not overlook the obvious. Nest you mention having installed a fuel line restrictor. You did remove this, right?
Now, on to the ignition system. Points or electronic? Neither one sshould cause the problem you describe, but either could. Plugs, cap/rotor and wires are NEW right? Old crappy wires will cause all kinds of badness. You advance mechanisms, both mechanical and vacuum work correctly? A bad mechanical advance will cause a high RPM breakup. Twist the rotor in the direction of rotation, it should spring back. A leaking vacuum advance will cause an off idle stumble, but you should be able to "step through" the flat spot. If you are running points make sure you set them with a dwell gauge, not just a feeler gauge (if there is a big difference, you center bushing is shot, and you need a new distributor.) How about the coil? I use a $12.99 universal as a troubleshoot coil...if the cheap piece of crap coil makes an engine run better, then it needs a new coil. If you are running electronic ignition, try a cheapo replacement spark box. As with the coil, it will either help or not. Electronic ignitions are somewhat sensitive to good voltage. Make sure all connections are clean.
This ought to give you some things to look at. AVOID SHOTGUN MAINTENANCE!!! Change one thing at a time and evaluate.
