Small Block
Guys i've got a Chrysler 331 Hemi motor to part out. It's a 52 model with the bell built onto the block. The complete heads are there as are the exhaust manifolds. It has a crank, rods and pistons. Only one valve cover and it is rough. I'll be tearing it apart as soon as i soak it awhile so be thinking of what pieces you want and PM me and i'll let ya know if they are there. The block is junk unless your going to cut off the bell and do some other work in the intake flange. I do see one rocker arm is cracked but there is a lot of good stuff here. Let me know and i'll get back to ya.
Small Block
West Plains, Mo 65775
Small Block
