On engine valve spring compressor
2009redrt
Member
Delaware
Indy 360-2 heads. Does anyone know if there's a tool to compress/replace the valve springs with the heads still mounted on the block? I have the tool to do this on W5 heads, but not the Indy heads.
Thanks for any help you can give.
Bill
I have found that those intended for overhead cam engines work well for engines with rocker shafts. I have an old KD Tool compressor made for the old Datsun OHC 4 and 6 cylinders that works good.
this is the one I got from Ed Hamburger many many years ago...it looks pretty simple and I have used it dozens of times on standard and w2 heads....
It would not be hard to copy.....
I use this one. Click the link below.
m.summitracing.com/parts/pro-67460
Duster360, does that one work on Indy heads?
As long as it has the shaft cradles like stock heads. Which I thought they did. I could be wrong though.
Here is a picture I found of the head. As long as the stands are in the stock location it will work great.
