Should hopefully finish porting the second one and do some 5 angle valve jobs and flow testing this weekend.
Which head? Oh I see, Speedmaster.Should hopefully finish porting the second one and do some 5 angle valve jobs and flow testing this weekend.
Looks great. I have to ask and I think you have mentioned the number before but, what percent of gain is after the valve job and bowl blending?
If my memory is correct, just the valve job and bowl blend was 80% of the gains on a 2.02 valve stock type heads.
Which head?
Which head?
John, what do you use to seal the pushrod tubes? Or do you use anything?
I bet that works good. We used to use a thin coat of K&W Block Seal for guides and other press in things as we felt the need. I'm not sure they even make it anymore. It was in a bottle similar to the size and shape anti seize is in and it had a ball shaped brush on the lid. It was good stuff!A very thin coat of JB Weld.
I found it! They just changed it up some.I remember it well.
I forgot about that stuff. Yes I like it too.If anyone is ever looking for a very good epoxy similar to JB weld but perhaps stronger. Check out marine Tex grey. Very good stuff.
