Only after warm up,...Issues
Slant 6 Engines
  1. FURY440
    FURY440 Well-Known Member
    262
    97
    Oct 20, 2016
    New Jersey
    Local Time:
    3:38 AM
    66 Valiant /6 225. Engine runs great, but after it's completely warmed up it starts to buck/surge while driving down the highway at all speeds and at idle,.it's a little rough. It seems to me it's like the ignition is shutting down intermittently or fuel? Anything anyone can think of to check?
    Thank you....
  2. Shogun1332
    Shogun1332 Member
    24
    24
    Sep 18, 2016
    Idaho
    Local Time:
    1:38 AM
    Fuel line running too close to the exhaust and boiling your gas after things start to get warmed up? Could be an almost plugged fuel filter as well, what all have you looked into?
  3. RedFish
    RedFish Well-Known Member
    25,109
    3461
    Sep 5, 2007
    Local Time:
    2:38 AM
    Fuel percolation. I think our member Slantsixdan has a fix for that.
  4. FURY440
    262
    97
    Oct 20, 2016
    New Jersey
    Local Time:
    3:38 AM
    Thank you. The fuel filter is new. Hopefully Slantsixdan will chime in.
  5. bbrroowwnn
    bbrroowwnn never re member
    12,464
    748
    Nov 27, 2010
    Drums, PA
    Local Time:
    3:38 AM
    1920 carb ?
  6. pishta
    pishta I know I'm right....
    20,414
    9686
    Oct 13, 2004
    Tustin, CA
    Local Time:
    12:38 AM
    My truck did that, it was fuel starvation due to a plugged filter. Does it idle fine when warm? Its probably not your new filter but vapor lock as stated. reroute your fuel line farther from the exhaust as Dan has noted. And maybe check your temperature of your coil when warm. It should not be burn your hand hot
    • Agree Agree x 1
    • RedFish
      25,109
      3461
      Sep 5, 2007
      Local Time:
      2:38 AM
      You might find the solution at slant6.org too.
    • slantsixdan
      slantsixdan =..=
      6,807
      2068
      Jan 7, 2007
      Vancouver BC
      Local Time:
      12:38 AM
    • FURY440
      262
      97
      Oct 20, 2016
      New Jersey
      Local Time:
      3:38 AM
      It's a 6-1695 Carter. We rebuilt it and like I said, runs great until it's warmed up.
    • FURY440
      262
      97
      Oct 20, 2016
      New Jersey
      Local Time:
      3:38 AM
      Hmmm? Very strange. The 1695 carb has constant vacuum at the vacuum advance port. With that said, it's always advanced. I unhooked and plugged the port on the carb (I haven't taken it out for a ride yet), but believe it or not it seems to be running better at idle then it was when the vacuum advance was hooked up. Anyone know why it would have constant vacuum at that port? That can't be a good thing!!
