Swedishdart
Streetracer
Crap, stupid son of a **+x*.*^.... Today i was going to fill the other half of my 440 engine with "block filler" I mixed it with water and poored it in but now here is the problem... i over filled the water jacket :sad9: the filler was i level with the under side of the water inlet. So when i light with a flashlite i the rear of the engine i cant see the light trough the inlet. If i´m lucky it will sink so much så i can at least se some litght tomorrow.. But what can i do if i will run the engine on the street? I use Stage VI heads so i can lead the water directly from the pump to the front side of the head and in te rear i will lead it over to the other head and then back to the pump.... Will it work?
