oooops on Piston choice
Mopar Performance Issues
  1. tooslow
    tooslow Well-Known Member
    594
    22
    Mar 8, 2011
    lockport, Il
    Local Time:
    2:15 AM
    I have a street Dart , 446, hughes solid cam 250 dur at 50 575 lift ,worked Stealth Al heads ,single plane intake ect....
    230 miles on rebuilt engine , Engines a dog , noticed my pistons are .120" below deck and my compression is pretty low . 130 psi average . I told machine shop I wanted as close to 0 deck as possible( 10.5 0 or 11.0 to 1) but I was busy working and I let the machine shop put it together. I usually assemble everything myself and check all clearances, plasti gage ect... and take my time because its my money and its fun. The owner of the machine shop passed away and shop was sold
    Otherwise i would take the engine back to them and work it out
    Situation
    I want to change my pistons to a KB 237,s , I calculate that I should be much closer to 0 deck . I haven't sat down with a sharp pencil to figure everything out exactly yet
    Question
    With 250 miles on a fresh engine can I simply just change the pistons . Street car and not a race car
    Do I have to take everything re balanced again ?
    • Disagree Disagree x 1
    • brian6pac
      brian6pac Well-Known Member
      4,653
      3137
      Nov 15, 2016
      N.E.Ohio
      Local Time:
      3:15 AM
      Just the piston weight will have to match.
      The rings can be reused if you keep them in the same hole
      • Agree Agree x 2
      • Locomotion
        Locomotion Well-Known Member
        2,917
        457
        May 31, 2004
        Florida
        Local Time:
        3:15 AM
        Unless you have a weight/balance card and compression height of the existing pistons, you won't have all the info you need until you take the pistons off the rods. Hypereutectic pistons require more ring gap than conventional cast or forged pistons and piston-to-wall clearance should be checked against recommendations. OEM deck clearances are usually more than factory spec.
        • Agree Agree x 1
        • tooslow
          594
          22
          Mar 8, 2011
          lockport, Il
          Local Time:
          2:15 AM
        • tooslow
          594
          22
          Mar 8, 2011
          lockport, Il
          Local Time:
          2:15 AM
          Thx guys
          Find a new mopar familiar
          machine shop in Chicagoland and take her over there , get the combo right .
        • moper
          moper FABO Gold Member FABO Gold Member
          15,709
          1846
          Dec 27, 2004
          eastern CT
          Local Time:
          8:15 AM
          It sounds like the cam's just too large for what you have. You based the choice on the want, not what they delivered. If it's a street car, I'd just leave the lower end and revise the cam choice. KBs are much lighter than the pistons you're likely to have if they sit that low in the block. So you're talking about new pistons, removing the old pistons they'll be pressed pin (again based on the "short" compression height of cheaper pistons) , balancing the assembly, pressing the new ones on, a quick touch up on the hone, and new rings. I'm not sure a couple points of compression are worth the work if the rest of the engine is good. Swap the cam to something with 10* less duration at .050. Maybe a solid lifter if you want a little more torque off idle. Then run it and enjoy.
          • Like Like x 1
          • Agree Agree x 1
          • jbc426
            jbc426 Well-Known Member
            1,811
            639
            May 30, 2007
            West Coast
            Local Time:
            12:15 AM
            FWIW, Smokey Yunik was said to have swapped pistons out that were over 100 grams heavier or lighter without touching the balance in some of his race engines back i the day with no noticeable vibration.
            I changed the pistons and cam in my 494" RB with the consultation and help of Dwayne Porter. He nailed it with my combination. Great man to work with and highly recommended even if its just to chat with him.
            • Like Like x 1
            • tooslow
              594
              22
              Mar 8, 2011
              lockport, Il
              Local Time:
              2:15 AM
              How do I contact Dwayne Porter ?
              Thanks for the advice but I want 550 hp so I pulled the engine and figuring out a good piston combo
            • AJ/FormS
              AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s
              18,265
              6496
              Jan 19, 2014
              South-Central Manitoba,Canada, 900ftelevation
              Local Time:
              2:15 AM
              What stall and gears.
              550 hp at 80 mph, and 125 at 1700 does not a good streeter make.
              400 ftlbs at 35/40mph is funtastic
              If your dogginess is below ~3000rpm, look to cylinder pressure, or stall. But after 3500 it shouldn't be a dog anymore. Your solution could be as easy as a higher stall, IDK
              As brian6pac said, and as I found out; hypers at 11/1 need more ring gap than specified in the catalog. I had to take my engine apart and open them up. I also run my (SBM) skirt clearance a lil looser than specified. IIRC mine are at .0035, but I run a minimum coolant temp of 205*F, and a standard transmission, so my revs are always up.
              But I agree; 130psi with alloy heads , is probably not the greatest street combo, lol.
            • K.O. SWINGER
              K.O. SWINGER Well-Known Member
              1,188
              439
              Nov 18, 2010
              oregon
              Local Time:
              2:15 AM
              as previously mentioned that is a lot of camshaft for the street, it could be made to work with the right Supporting Cast, converter, high rear end ratio Etc. But as far as Pistons go I would look at Icon forged they will be close to stock piston in weight and will give you the compression you're looking for
            • rumblefish360
              rumblefish360 So close, yet so far away FABO Gold Member
              38,078
              9750
              Jun 21, 2005
              New York, on a Island
              Local Time:
              3:15 AM
              If the new pistons diameter is the same and if the same metal make, then you can swap them in minus a possible rebalancing. Pistons need to be weighed.
              (You’ll need a rebalancing...)
            • 512Stroker
              512Stroker We are all here because we are not all there.
              1,461
              1017
              May 30, 2016
              Freedom, MO
              Local Time:
              2:15 AM
              It's a bitch when a engine build does not meet your expectations, been there hated that.
              And it is not your fault.
              I wont even attempt on a recommendation to fix it right.
              If the machine shop screwed up a basic fundamental like piston height I would not trust much of the other work they did.
              Good luck
            • tooslow
              594
              22
              Mar 8, 2011
              lockport, Il
              Local Time:
              2:15 AM
              When i say street, I mean i drive it on the highway, frontage roads around my house and cruise towns rarely . The Dart has a suspension , DR Diff upgrades Brakes , Flaming River steering box , frame connectors , 6 point cage . I take the car to Road America for track days and Autobahn by my house . It isnt meant to be a Stop light car. I will drive it to Ohio if we have the Mopar event this fall
              4 speed (tremac 5 speed would be nice , someday)
              3.23 gears
              M1 intake
              EFI( had trouble with stalling in corners with a Carb)
              Note: I could not get a carb with floats to work with hard corners, people do it all the time but never could find the answer until EFI?
              stealth heads -stock
              Oil Accumulator
              3000(2500) to 6000 is rpm range
              I cruise 70 around 3000RPM on the highway
              From what you are all your saying you are in a agreement ,if I do not want to change my cam. I need Compression, 550 hp was my intent. I specified 11 to 1 at the machine shop and it is what I though i was getting. water under the bridge, getting on with it now. about 120 to 125 psi right now
              Hughes 250 dur 575 lift @ 50 ( aprox #s) is the Cam I have and would like to stay with
              Thx for replies
              • Like Like x 1
              • 512Stroker
                1,461
                1017
                May 30, 2016
                Freedom, MO
                Local Time:
                2:15 AM
                Please keep posting your results.
                I love Road America I used to live 8 miles away from the track.
                They ain't kidding when they call it "Gods Country".
              • oldkimmer
                oldkimmer FABO Gold Member FABO Gold Member
                15,360
                4235
                Nov 11, 2006
                Kindersley, Saskatchewan,
                Local Time:
                2:15 AM
                U should be able to find a forged piston close in weight to what u have. Most likely will be heavier. Then u can take weight out of the piston to match to your pistons. Win win that way. Kim
              • K.O. SWINGER
                1,188
                439
                Nov 18, 2010
                oregon
                Local Time:
                2:15 AM
                Your car sounds kind of awesome would love to see some pictures.
              • Marcohotrod
                Marcohotrod Well-Known Member
                2,411
                619
                Mar 21, 2015
                Massachusetts
                Local Time:
                3:15 AM
                what did the stock pistons weigh? was it rebalanced for the .120" down pistons and what did they weigh? I agree with Smokey and Ed Hamburger - swapping pistons within 10% weight - and below 6500 rpm can be fine without rebalance. what numbers are on .120" pistons? stock 440 pistons weighed from 820 grams to 870
              • tooslow
                594
                22
                Mar 8, 2011
                lockport, Il
                Local Time:
                2:15 AM
              • tooslow
                594
                22
                Mar 8, 2011
                lockport, Il
                Local Time:
                2:15 AM
                512stroker
                MVP is the club I do track days with
                Are interested in going to the next event at RA
                • Like Like x 1
                • QuickDart360
                  QuickDart360 Well-Known Member
                  1,150
                  406
                  Apr 5, 2014
                  San Antonio
                  Local Time:
                  2:15 AM
                  I changed from stock 360 pistons to KB107 flat top pistons without any balance like 16 years ago. Did unknowingly!! Engine seems to be strong and no vibrations after all these years. Did follow ring gap recommendation as per instructions.
                  • Thanks! Thanks! x 1
