Hello everyone,
Having never set up a center section on my own I am in need of a little guidance. I have an 8 3/4 489 center with 3.23 gears. I wish to remove the open carrier and install my powr lock clutch style sure grip unit using the same gears. Since I wont be removing pinion from case, if I set the side adjusters back in the same amount of turns will my gears still be patterned correctly? Thanks for the help everyone.
