came across this engine that we are considering to put in a 73 Scamp drag car
motor was built somewhat to nascar specs.
340 R3 48 degree block - 358 cubic inch
Bryant crank 3.30 stroke
carillo rods 6.25"
diamond 4.155 flat tops -
crane solid roller - duration 266/270 @ .05, lift 726/610
Jesel pro series rockers 1.65 int 1.5 exh
12 to 1 compression
dry sump oil system
w8 heads 2.18 int, 1.625 exh, nextek springs, titanium retainers etc
w8 MP intake
crank trigger / MSD distributor
dyno sheets show max torque 523 at 5800 rpm,
max HP 685 at 7500 rpm
would this be ideal in the Scamp ?
carillo rods 6.25"
12 to 1 compression
dry sump oil system
w8 MP intake
