Original 340 Exhaust Systems Help
Small Block Mopar Engine
  1. Road Grabber
    Road Grabber Member
    21
    0
    Jun 30, 2020
    Cape Vincent New York
    Local Time:
    7:44 AM
    I am looking for a vendor for an original 340 exhaust system using the cast iron manifolds for a 1970 Dart Swinger. Did these cars use an "H" pipe? I also see "X" pipes? 2.5 pipes? 2-1/4? I would want at least and aluminized system if not stainless. Any advice for mufflers? I intend to use the exhaust tips as well. Thanks
  2. Sublime Swinger
    Sublime Swinger Well-Known Member
    164
    36
    Sep 15, 2013
    Minnesota
    Local Time:
    6:44 AM
    Accurate exhaust or TTI have some great products.
    • Agree Agree x 2
    • davescuda
      davescuda FABO Gold Member FABO Gold Member
      9,965
      1505
      Apr 30, 2007
      Cheshire, CT
      Local Time:
      6:44 AM
      or Dons, his are copied from NOS pipes
      • Agree Agree x 2
      • Like Like x 1
      • Thanks! Thanks! x 1
      • Car Nut
        Car Nut Mopar Master
        15,213
        65655
        Dec 28, 2018
        Zombieland
        Local Time:
        5:44 AM
        TTi will custom bend a complete exhaust in 304 stainless “H” or “X” from manifolds back.
      • tonysrt
        tonysrt FABO Gold Member FABO Gold Member
        723
        341
        Dec 25, 2016
        Northport, NY
        Local Time:
        7:44 AM
        From the factory they didn't use X or H exhaust back then.
        • Agree Agree x 5
        • Mike69cuda
          Mike69cuda 64 is the new 17 FABO Gold Member
          1,584
          1181
          Jan 2, 2018
          Overland Park Kansas
          Local Time:
          6:44 AM
          I bought mine from Waldron exhaust. Nice family run operation. They are a little slow, but were about half price of Accurate & it fit well.
          • Agree Agree x 3
          • ir3333
            ir3333 Well-Known Member
            4,633
            1192
            Jun 1, 2008
            ontario,canada
            Local Time:
            6:44 AM
            e bay item # 184285805697
            watch..they usually come on sale for $444
            • kursplat
              kursplat FABO Gold Member FABO Gold Member
              2,968
              1948
              Aug 24, 2010
              so cal
              Local Time:
              4:44 AM
              Accurate will reproduce the dents for you if you like
            • Mattax
              Mattax Just the facts, ma'am FABO Gold Member
              10,747
              6747
              Feb 7, 2013
              Phila. Pa
              Local Time:
              7:44 AM
              Don's will get you a very close reproduction. They might be at Carlisle right now.
              No X.
              I'm not 100% positive for 1970 but there was no H on 340s in 1968 and 69. Look in the shop manual.
              Differences I'm aware of from the pre 70 cars that might be releavant to your 70.
              Accurate's pipes use the correct muffler hangers, but last I checked, not the correct tail pipe hangers.
              TTI uses the correct tail pipe hanger but hangs the mufflers their own way.
              Accurate's headpipe gasket is a nice repop with a fire ring.
              • Like Like x 2
              • Nat
                Nat Well-Known Member
                264
                146
                Jun 11, 2019
                Netherland
                Local Time:
                7:44 AM
                don't think factory made x or h pipes , i have the TTI system aluminized which is a waste of money they look like crap after 2 years stainless is the way i'll go next time factory correct or not
                • doug 371
                  doug 371 Well-Known Member
                  1,962
                  207
                  May 29, 2004
                  Regina, SK CANADA
                  Local Time:
                  12:44 PM
                  tti's tail pipe hanger is not correct in my experience
                  • Thanks! Thanks! x 3
                  • Agree Agree x 1
                  • Road Grabber
                    Road Grabber Member
                    21
                    0
                    Jun 30, 2020
                    Local Time:
                    7:44 AM
                    Thanks for all the posts. I was going to carlisle but a friend that went said many dealers didn't show. It's 6 hours for me. Maybe next year. I will call to see about the best fit and if I can get stainless. I did use the aluminum for a past project. it's been over 20 years and still in good shape but if I can get stainless that's a big plus.
                    As far as the hangers, if I get the right hangers from someone else I wonder if they will work with the TTI? I will mention it to them and see if they are aware of this.
                    Does anyone know what treatment or what is best to do with the stock cast iron updrafts? They look like crap later as compared to a lot of other detail work done oin the engine compartment. I used Eastwood paint in the past. It lasted awhile...
                  • Road Grabber
                    Road Grabber Member
                    21
                    0
                    Jun 30, 2020
                    Local Time:
                    7:44 AM
                    Can you provide the full name of "Don's"...?
                  • Road Grabber
                    Road Grabber Member
                    21
                    0
                    Jun 30, 2020
                    Local Time:
                    7:44 AM
                    Don's ? I couldn't find them in a google search. What's the full name of the vendor please.
                  • davescuda
                    9,965
                    1505
                    Apr 30, 2007
                    Cheshire, CT
                    Local Time:
                    6:44 AM
                    i will get it for you
                  • 66fs
                    66fs FABO Gold Member FABO Gold Member
                    4,783
                    1484
                    Sep 9, 2009
                    Greenwood, South Carolina
                    Local Time:
                    7:44 AM
                    • kursplat
                      2,968
                      1948
                      Aug 24, 2010
                      so cal
                      Local Time:
                      4:44 AM
                      do they use salt on the roads there?
                    • Car Nut
                      15,213
                      65655
                      Dec 28, 2018
                      Zombieland
                      Local Time:
                      5:44 AM
                      • Like Like x 1
                      • Road Grabber
                        Road Grabber Member
                        21
                        0
                        Jun 30, 2020
                        Local Time:
                        7:44 AM
                        Yes but I never drive it in the salt.
                      • Mattax
                        10,747
                        6747
                        Feb 7, 2013
                        Phila. Pa
                        Local Time:
                        7:44 AM
                        Don's Custom Exhaust
                        1231 Cleveland Ave SW
                        Canton Ohio 44707
                        Send me a PM if you need phone or e-mail because I think its against the rules to post phone numbers in a thread.
                        • Like Like x 2
                        • davescuda
                          9,965
                          1505
                          Apr 30, 2007
                          Cheshire, CT
                          Local Time:
                          6:44 AM
                          Thanks I was looking for his card. They were at Carlisle this year
                        • Nat
                          264
                          146
                          Jun 11, 2019
                          Netherland
                          Local Time:
                          7:44 AM
                          never winter or wet road driven , caught in the rain a few times , but not a regular thing
                        • Road Grabber
                          Road Grabber Member
                          21
                          0
                          Jun 30, 2020
                          Local Time:
                          7:44 AM
                          Thanks for this info. I will give these vendors a call.
                          Does anyone know what's out there for the cast iron updrafts manifolds? Treatments?
                        • ir3333
                          4,633
                          1192
                          Jun 1, 2008
                          ontario,canada
                          Local Time:
                          6:44 AM
                          stainless just doesn't look right on a restoration.Aluminized looks correct and mine is like new after 5 years use.
                          I don't drive in salt or snow either.
                          • Like Like x 1
                          • Wyrmrider
                            Wyrmrider FABO Gold Member FABO Gold Member
                            3,466
                            1658
                            Sep 5, 2016
                            los angeles
                            Local Time:
                            4:44 AM
                            updrafts?
