GoodysGotaCuda
Mr. Goody
I have had a 650cfm Thunder AVS on my 318 for about three years now.
Its a slightly worked over 318, 3500stall, 3.91s, it currently runs mid 13s, when it was jetted too lean. The issue I am having right now is one bowl on the carb is getting sucked dry on heavy throttle, even sometimes rolling into the throttle slowly . Engine falls flat on its face.
I have:
New fuel system, 3/8" Lines, sender to regulator. Holley blue pump, set at 6psi, tried it at 7psi..No change in problem.
I have setup a dual feed for the carb, both -6an fittings
I have high flow needle & seats. 110" if i remember right
I have 'Pink' Metering rod springs
I am running .075x.037 metering rods with .107" primary, and .119" secondary jets. (rich, very. biggest secondary jet availible)
I have checked, and rechecked float level
*I am wondering if too light of a metering rod spring could cause this?
*Am I out running this carb for fuel with the jetting i have in it? It holds a good air/fuel ratio with the current setup, I just can't get it to run straight and am wondering if I am out-flowing the carb?
*Is there a possibility that a needle can be sticking in the seat with 6/7psi of fuel pressure against it?
Thanks! I feel like im overlooking something stupid....but dang, this ones gotten me good!
-Mike
I have:
-Mike
